1.喷丸机表面的残余压应力的强弱和应力层的高层度取决于工件材料的结构和喷丸强度。材料的结构复杂、硬度高,压应力就越大,压应力层也比较浅。提高喷丸强度可以改善压应力层高层度。通过对渗碳处理齿轮的分析,对比未喷丸机与喷丸工件的材料结构2.喷丸机后工件表层的显微结构发生变化,科学的喷丸机工艺可以显著提高表面硬度,对表面0.1mm的范围进行显微硬度测试,工件表层显微硬度明显提高,心部结构硬度基本相同,表层的硬度显著提高是受到搞的压残余应力、加工硬度和结构变化综合作用的结果。3.喷丸机后工件通过电子扫描显微镜观察发现,马氏体的微观亚结构被细化,残留奥氏体诱发转变为马氏体,用光学显微摄影仪观察,通过观察马氏体针得到很好的结论,再通过x射线衍射仪显示的衍射图判断,结构结果的变化有利于残余压应力的提高。结论:1.喷丸机可以清理工件的油污、毛刺,取得轻度倒圆角光饰性,增强耐磨、润滑和耐腐蚀的功能;2.喷丸机强化可以显著提高工件表面的残余应力,提高工件的疲劳寿命;3.喷丸机使渗碳表面硬度增加,降低疲劳断裂和应力应力腐蚀(含氢脆)断裂,效果很明显。4.喷丸机能够使工件表层的结构强化,即残余奥氏体发生诱发马氏体转变,并能够细化马氏体的亚结构。1piecedeepcompressiveresidualstressesandstressshotpeeningthesurfaceofthelayerdependsonthestrengthofthestructureandstrengthoftheworkpiecematerialblasting.Materialswithacomplex,highhardness,thegreaterthecompressivestress,thecompressivestresslayerisrelativelyshallow.Shotpeeningintensitycanbeimprovedtoimprovethecompressionstresslayerdepth.Throughtheanalysisofcarburizinggear,materialsandtissuecontrastisnotshotpeeningworkpiece2microstructureoftheworkpiecesurfaceaftershotchangescientificpeeningprocessmaysignificantlyincreasethesurfacehardness,thesurfaceofarangeof0.1mmforthemicrohardnesstest,thesurfacehardnessoftheworkpiecesignificantlyimprovedhearttissuehardnesssubstantiallysame,thesurfacehardnessissignificantlyincreasedbythepressuretoengageinresidualstresses,hardnessandprocessingtheresultsofthecombinedeffectsoforganizationalchange.3aftertheblastingaworkpiecebyscanningelectronmicroscopyrevealedthatthestructureofmartensitemicrostructureisrefinedsub??residualausteniteintomartensiteinducedbyopticalmicroscopicobservationofphotographicapparatus,themartensiteobtainedbyobservingtheneedlegoodconclusion,andthendisplayedbyx-raydiffractiontodeterminethediffractionpattern,theresultoforganizationalchangeswillhelpimprovethecompressiveresidualstresses.Conclusion:1shottocleanuptheoilworkpiece,burrs,made??slightroundingpolisher,enhancedwear,lubricationandcorrosion-resistantfeatures;2peeningsurfacecansignificantlyimprovetheresidualstressandimprovethefatiguelifeoftheworkpiece;3Shotcarburizedsurfacehardnessincreases,reducingfatigueandstressfracturestresscorrosion(includinghydrogenembrittlement)fracture,theeffectisobvious.4Shotenablesorganizationstostrengthentheworkpiecesurface,whichinducedmartensitictransformationofresidualausteniteandmartensitecanrefinesubstructure. [详情]
海吉川机械科技有限公司是吉川国际在华东地区设立主力制造基地。本公司专业制造销售:表面处理核心产品---“吉川牌”环保自动喷砂机、环保型喷砂房、环保型高中档喷砂机、配套直销各类机器配套零配件、易损件耗材、喷丸机厂家,喷砂、抛丸磨料;上海吉川机械座落在上海嘉定马陆镇马东工业园区。本公司成立之要点为:长三角华东区域各省、市的广大顾客提供服务配套的是技术难题咨询,解决了华东区广大顾客的后顾之忧;目前,上海吉川机械科技有限公司是国内长三角地区较有先进技术实力的表面处理设备制造公司,拥有多位当今国内较优异的行业研发高等工程师(中国喷砂行业标准制定者),更是名副其实较专业的喷砂机、抛丸机制造和服务厂家。HaijiChuanMachineryCo.,Ltd.isaninternationalestablishmentYoshikawamainmanufacturingbaseinEastChina.Thecompanyspecializesinthemanufactureandsale:Finishcoreproducts---"Yoshikawabrand"greenautomaticsandblastingmachine,sandblastingroomenvironmentallyfriendly,eco-friendlyhighprofileblastingmachine,supportingdirectsupportvarioustypesofmachineryspareparts,consumablesupplies,sandblasting,shotblastingabrasive;onHaijiChuanmachineryislocatedinShanghaisJiadingMaluTown,MaDongindustrialPark.ThefocusoftheCompanyisestablishedare:theYangtzeRiverDeltainEastChinaprovinces,themajorityofcustomerstoprovideservicessupportingthecityisconsultingtechnicalproblemstosolvethemajorityofcustomerstoworryabouttheEasternRegion;Currently,theHaijiChuanMachineryCo.,Ltd.istheYangtzeRiverDeltaregionisthemostadvancedtechnicalstrengthofsurfacetreatmentequipmentmanufacturingcompany,todayhasanumberofthenationstopindustryR&DSeniorEngineer(Chinasandblastingindustrystandard-setter),itisaveritablemostprofessionalblastingmachine,shotblastingmachinemanufacturingandservicemanufacturers. [详情]
喷砂机的喷枪数量是根据喷砂机当初设计时定制的,喷枪由:喷咀、砂咀、气咀、枪体、塑套组成。喷咀较终决定喷砂的效率和空压机的耗气量喷砂机的喷枪数量是根据喷砂机当初设计时定制的,喷枪由:喷咀、砂咀、气咀、枪体、塑套组成。喷咀较终决定喷砂的效率和空压机的耗气量。枪的数量越多,加工效率越快,相反使用空压机的气源也就越高。一般普压喷砂机的喷枪一支喷咀在8mm耗气量为0.8立方每分钟。喷枪在喷砂机使用当中属于易损件,所以平常的维护和保养是非常关键。维护保养的好和坏会直接影响喷枪的使用寿命和运行成本。刚开始喷砂机选用的喷枪材料应该选用较好的,枪体选用铸铝、砂咀,气咀选用铜材质,喷咀选用进口碳化硼。这样可以延长以后的使用时间。喷砂机保养应该注意:1砂料的选择,一般选用质量较好的砂料,通常的有棕刚玉、白刚玉、绿碳化硅、玻璃微珠、树脂砂、钢砂、钢丸等。具体选用的砂料应该根据实际的工艺要求来选择。2每种砂的硬度和形状不一样,一般来讲硬度越大,形状为菱角状的砂料,对于喷枪的损坏会越快,所以碰到类似的砂料,应该要勤检查喷枪、喷咀的口径,一般在7天检查一次。一般硬度叫小的砂料,形状为圆形的砂料,检查周期可为15天检查一次。3碰到砂咀、气咀、枪体有磨损孔,要及时更换,以免造成更大的磨损量。喷咀的口径在以前的口径加大到30%时,要及时更换。以免造成气源的浪费。4喷枪更换时那个零件磨损就更换那个,不要整套更换,不要造成成本的浪费。5购买喷枪应该到正规的企业购买,以免造成必要的损失。 [详情]
吉川机械为PM2.5排放献出微薄贡献随着工业经济的快速发展,随之给人带来的也是环境的高度污染,近几年来,环境污染是越来越严重,一些城市已经出现了严重污染,达到了500微米/立方米以上的数据。产生PM2.5污染颗粒的约60%来源于燃煤、机动车燃油、工业使用燃料等燃烧过程,23%来源于扬尘,17%来源于涂料等溶剂使用及其它吉川机械是专注于表面处理喷砂机、喷丸机、抛丸机设计及制造企业。喷砂机、喷丸机抛丸机也是替代高度污染酸洗、化学等表面处理工艺的一种设备。目前国内将近还有80%企业使用酸洗化学工艺解决表面清理问题,有10%企业干脆就不做表面处理工艺,导致产品的涂层短时间就脱落,严重的造成环境的污染。酸洗化学工艺解决表面处理问题不但对人体有严重的伤害,而且经过处理的废水不允许排放,需要经过多次废水处理才能达到排放标准,由于废水处理工艺成本非常高,大部分企业目前都是偷偷的直径排放,这样对环境造成了特别大的污染。喷砂机、抛丸机是一种替代酸洗,解决表面处理的新工艺,具有处理效果干净、还可以增加产品表面的附着力,是目前表面处理较佳的一种方式。但是喷砂机、抛丸机废气排放也是喷砂抛丸企业技术含量比较高的问题,目前工业标准排放指标为60微米/立方米。吉川公司近几年针对除尘器排放投入大量人力和财力,公司目标是力争达到根据PM2.5检测网的空气质量新标准,24小时平均值标准值分布如下:优:0~35微米/立方米的标准。经过这些年的努力,吉川公司喷砂机、喷丸机、抛丸机除尘器排放标准有新的打破,目前吉川公司承诺,吉川牌喷砂机,除尘器排放标准可以达到较低10微米/立方米。这一数据将达到了PM2.5较优的数据。 [详情]
平时经常碰到客户会问,喷砂sa清洁度是什么!喷砂Sa等级怎么确定!那个喷砂Sa等级更好等!作为喷砂行业十几年的我在这里给大家介绍一下Sa等级,让大家多了解一些喷砂清洁度处理标准,也希望能够给使用厂家一个衡量尺度,让大家更能对喷砂工艺的更多了解。Sa清理等级在世界上公认的两各标准:一、是瑞典在1976年制定的Sa级别。二、1985年美国制定的SSPC级别。因为瑞典首先制定的这个标准,所以现在基本上都是以Sa级别来衡量清理等级的标准。Sa一共分为四级,Sa1、Sa2、Sa2.5、Sa3Sa1:一般是采用工件表面简单的手工刷除、纱布打磨的方法,是四种清洁度中较低的一级,对涂层的保护仅仅好于未处理的工件。Sa1级处理的技术标准是,工件表面不可见油污、油脂、残留氧化皮、锈斑和残留油漆等污物。Sa2:一般是喷砂的方法进行清理,Sa2级别是喷砂处理中较低的一级,也就是一般要求,但对涂层的保护要比手工刷清除提高了很多。Sa2的技术标准:工件表面不可见油污、氧化皮、锈皮、腐蚀物和其他外来物质。如工件表面有凹痕,则轻微的锈蚀和油漆还会残留凹痕底部。Sa2.5这一级别是工业上普遍使用的并可以作为验收技术要求及标准级别。Sa2.5级处理的技术标准:同Sa2要求前半部一样,但疵点限定为不超过每平方米表面的5--8%,可包括轻微暗影;少量因疵点、锈蚀引起的轻微脱色;氧化皮及油漆疵点。蚀引起的轻微脱色;氧化皮及油漆疵点。Sa3这种级别是工业上高等要求处理级别。Sa3处理的技术标准与Sa2.5级别一样,但是比Sa2.5级别处理的阴影、锈蚀等更完全,这些阴影、锈蚀等都不存在。一般来讲,清理的等级越高,清理的效率就越慢,同样清理的成本就越高。更多的喷砂知识请登录:http://www.jckpsj.com [详情]
铝型材专项使用喷砂机在使用规定的磨料并满足规定的压缩空气条件下,应能正常工作,喷枪射出的磨料流应连续稳定,磨料流的间歇时间不大于1秒钟。磨料流量调节装置应灵敏、有效、可靠、方便。各运行机构不应有卡阻现象。磨料循环系统应能连续可靠地循环磨料,磨料在循环系统中没有堆积和堵塞现象。喷砂舱、磨料循环和除尘系统及其管道等工作时无泄漏。除尘系统应使喷砂舱内处于负压状态,喷砂舱内具有不影响喷砂操作的可视能见度。铝型材专项使用喷砂机操作点的粉尘浓度和排入大气的粉尘浓度符合5.1.5和5.1.6的要求。铝型材专项使用喷砂机的系统噪声符合5.1.8、5.1.9或5.1.10的要求。喷砂舱的照度符合5.1.7的要求。铝型材专项使用喷砂机的操作控制系统和安全控制系统正确、有效、可靠。在规定的喷砂工艺条件下进行喷砂加工,加工质量和效率符合设计要求或供需双方的约定要求。Undertheprovisionsofsandblastingmachineusingabrasiveconditionsandmeettherequirementsofcompressedairshouldbeabletoworkproperly,thegunshotabrasiveflowshouldbecontinuousandstable,intermittenttimeabrasiveflowisnotgreaterthan1second.Abrasiveflowregulatingdeviceshouldbesensitive,valid,reliable,andconvenient.Eachagencyshouldnothaverunjammingphenomenon.Abrasivecirculationsystemshouldbecontinuouslyandreliablyabrasivecycles,noaccumulationandcloggingoftheabrasiveinthecirculatorysystem.Blastingcabin,abrasivedustremovalsystemanditscirculationandpipingworkwithoutleakage.Dedustingsystemshouldenableblastingcabininavacuumstate,sandblastingcabinwithblastingoperationsdonotaffectthevisualvisibility.Dustconcentrationsandblastingmachineoperatingpointsanddustconcentrationintotheatmospheremeetstherequirementsof5.1.5and5.1.6.Systemnoiseblastingmachinemeetstherequirements5.1.8,5.1.9or5.1.10.Sandblastingcabinilluminationtomeettherequirementsof5.1.7.Operationcontrolsystemandsecuritycontrolsystemsblastingmachineiscorrect,effective,andreliable.Sandblastingsandblastingprocessunderspecifiedconditions,processingqualityandefficiencyinlinewiththeagreeddesignrequirementsortherequirementsofbothsupplyanddemand. [详情]
